Good morning,
I am working on a customization to the Time and Expense entry form. I would like to add some code to the forms ‘on close’ event. This would look at all the labor transactions for the selected employee/date. If any of the transactions still have status of “Entered”, then pop up a text box to remind the user to submit before closing.
Normally closing the TE form saves “entered” transactions because we have that check box ticked. However, if you open a transaction and “Recall” it, then you can close the form without getting a reminder to save first, thus leaving an unapproved transaction.
So my question is, how do I access the list of transactions loaded for a particular date, then iterate over those transactions to check each one’s status?
From the trace, I see a method called: Erp.Proxy.BO.LaborImpl.GetRowsCalendarView() Can I access the results of this method call from my on close event?
This is some placeholder code that will need to be updated to include a break out if there are any labor transactions still unapproved.
private void TimeExpenseForm_Closing(object sender, System.ComponentModel.CancelEventArgs args)
String myRef ="5b2c4aba-7b90-42e1-a0fe-ef9097392c89";
EpiUltraCombo statCombo;
statCombo = (EpiUltraCombo)csm.GetNativeControlReference(myRef);
MessageBox.Show("Don't forget to approve this labor transaction!" + statCombo.Text);
*Bump - Anyone have any ideas on iterating through the records for this form?
