It's here.... 2026.1.100 Feedback Thread (Behave 🤣 )
Yikes…it shouldn’t be erroring out period. Can’t just chase everyone off the system just to run MRP either…
@JMPCONJ when Epicor was on site for our CVEW, their Solutions Engineer encouraged us to run 3 for Number of MRP Processes. She was pretty passionate about making that change. I don’t remember exactly why…this workshop was back in October '25.
There is a science to it, not just random 3. They should have you run some commands to determine how many CPUs you have, threads, cores. Sigh.
Its even documented in Epicor Help somewhere.
3 is the max for SaaS.
How does a Custom Truck Manufacturer run MRP in time? We had to use 8, because the BOM was huge and created about 20-50 Child Jobs. SaaS can’t handle a decent size company that’s not manufacturing tissue paper? :thinking: About 2.5 million parts.
Stay on-prem?
:man_shrugging:
There is rumor of some kind of ā€œhybridā€ Containers Epicor is working on.
Back in the day (E9?), when this setting first appeared (and EVERYONE was oon-prem), we were taught it referred to the number of processor cores devoted to the process, and depending on A LOT of factors, the law of diminishing returns comes into play at some point. In my environment at the time, 4 was my sweet spot. I remember people telling me that in THEIR environment they could see improvement up to 8 or 10, so it probably DOES depend on a lot of other things, INCLUDING the data that MRP is crunching through.
I have also been told that 3 is the limit for SaaS, regardless of what higher value you may enter there, you’ll only ever get 3. Probably the only way to test that is to make it 5, turn on logging, and see how many log files you get (you’ll get one per core).
EDIT: Running with a single processor and single scheduler means there’s probably no chance of a thread finding stale data somewhere.
If that’s what they recommended, follow their lead…I just pulled our setup…YMMV.
Ernie, you are 100% correct, as we are a SaaS company and therefore 3 makes sense for us. Also, gone are the days of on-prem, here soon. Honestly, I loved having everything on-prem, dating back to V6!
Used to be 3 but was reduced in the last year.
From Kinetic Material Requirements Planning Guide 2026.100 page 239:
I just saw that and was going to test it tonight.
I just kicked off MRP in a PILOT environment with ā€œ5ā€, and it gave me an error saying I could only use ā€œ3ā€. I changed it to three and it is now running (with MRP logging enabled). I’ll see what happens and report back.
That’s fair play. Documenters and developers are different teams.
cool hand luke cowboy GIF
black and white smile GIF
yeah my brain also instantly started humming Civil War and now it’s stuck there, the way it’s always done before
help
…failure to communicate…
I got three log files… the documentation is incorrect (right now) but that may be the way it’s gonna be at some point.
Same issue for us.
Worked (but took a lot longer) when we used 1 scheduler.
Apparently this is fixed in hotfix 100.9
Ditto but different custom truck OEM, and we used 7.
I accidentally looked into this a few months ago. For us, 7 was excessive; probably 5 would have sufficed… except for the fact that some nights 5 of them would fail, leaving only 2 to carry the load. So if we had started with 5, that would leave […calculating…] zero.
Some MRP processes fail but MRP completes… more or less - Kinetic ERP - Epicor User Help Forum
When I was on MT SaaS in 2017, we’d crash MRP if was more than one process.
Cloud Migration considerations and advice - Epicor ERP 10 - Epicor User Help Forum
