Job Adjustment Help
Still looking for help with this one...
Brad
--- In vantage@yahoogroups.com, "brad.ebright" <bebright@...> wrote:
> I made a report taht shows when the burden rate for a job was wrong.
> This was designed to have someone go into job adjustment and make the
> corrections. However, when we re-run the report, the numbers are
> different, but not correct, because it is not taking into account the
> adjustments. When I check what table the adjustments are going into,
it
> says laborview. However, there is no LaborView table. Can someone
point
> me in the direction to check where these adjustments are going?
adjustments. When I check what table the adjustments are going into, it
says laborview. However, there is no LaborView table. Can someone point
