I just need to verify that the Job Completion Tracker is only populated based on the Job Completion Process. Is this correct?
The Job Completion Exception Tracker shows any jobs that were not within the Auto-Completion parameters that are set up in the Job Complete/Close Parameters after you run the Auto-Job Completion Process.
