While using Job Cost adjustment, on one of the Operations, it gives the following error. I am not sure where the -16 is coming from. Nothing in the job for this operation shows that.
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: An error occurred trying to set a value of ‘-16.28’ in an EpiNumericEditor. The controls EpiBinding is ‘LaborView.ActSetupHours’.
Inner Exception Message: The ‘Value’ property cannot be set to a value that is outside the range determined by the ‘MinValue’ and ‘MaxValue’ properties
Program: Ice.Lib.EpiClientLib.dll
Method: SetValueWithExceptionChecking
Client Stack Trace
at Ice.Lib.Framework.EpiNumericEditor.SetValueWithExceptionChecking(Object value)
at Ice.Lib.Framework.EpiNumericEditor.oDataView_EpiViewNotification(EpiDataView view, EpiNotifyArgs ar)
at Ice.Lib.Framework.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.OnEpiViewNotification(EpiNotifyArgs e)
at Ice.Lib.Framework.EpiDataView.Notify(EpiNotifyArgs args)
at Ice.Lib.Framework.EpiUltraCombo.updateDataSource(Object sender, Boolean forceUpdate)
Inner Exception
at Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value(Object value)
