Job Entry changes after closed
If that customization is a BPM or auto-print rule, an updatable
dashboard will trigger it.
But if it's a screen customization only... huh. You can try setting
extended properties on those fields, the hard part might be getting your
code to run after Epicor's regular "disable-if-job-closed" code has
completed.
Brian.
Of Joshua Giese
Sent: Friday, July 27, 2012 4:10 PM
Subject: RE: [Vantage] Job Entry changes after closed
There is special functionality in the customization. It's used to
trigger
label printing.
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Behalf
Of Brian Roberts
Sent: Friday, July 27, 2012 2:51 PM
Use an updatable dashboard?
Brian.
Behalf
Of Anon
Sent: Friday, July 27, 2012 2:32 PM
Subject: [Vantage] Job Entry changes after closed
I have some custom fields being used in Job Entry that we would like the
ability to edit even after the job is closed. They are more
informational than anything. Is this possible? They go to disabled with
all the other fields when the job is closed.
I have some custom fields being used in Job Entry that we would like the ability to edit even after the job is closed. They are more informational than anything. Is this possible? They go to disabled with all the other fields when the job is closed.
Brian.
Of Anon
There is special functionality in the customization. It's used to trigger
label printing.
Joshua Giese
CTO
Of Brian Roberts
Brian.
Behalf
Of Anon
What if you used a UD table as a child or just keyed the same, then the dataview wouldn't disable them. More work to update, but separate and you could use a data directive to slide them back into Jobhead.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
label printing.
Joshua Giese
CTO
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Brian Roberts
Brian.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Anon
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
