Job Entry Error - "value does not match the mask"
It looks like your hand full of troublesome v4 imported jobs were imported with a JobHead.JobNum value (or some other related table JobNum field value) that either has some garbage character imbedded (and likely not visible - like a carriage return) that is confounding the GetByID method OR resulting in corrupt relationships between the multiple tables that actually make up a job.
sanfranc415 <sanfranc415@...> wrote:
We have some old jobs from version 4 that are coming up with this
error message:
Error Detail
Stack Trace
at Infragistics.Win.UltraWinMaskedEdit.InputCharBase.set_Char(Char
value)
at Infragistics.Win.UltraWinMaskedEdit.NumberSection.SetText(String
text)
at
Infragistics.Win.EditorWithMask.SetDoubleValue(SectionsCollection
sections, Double val, MaskInfo maskInfo)
at Infragistics.Win.EditorWithMask.SetDataValue(SectionsCollection
sections, Type dataType, Object val, MaskInfo maskInfo)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.SetValue(Object val)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.set_Value(Object value)
at Infragistics.Win.EditorWithMask.set_Value(Object value)
at
Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value(Object
value)
at
Epicor.Mfg.UI.FrameWork.EpiNumericEditor.oDataView_EpiViewNotification(EpiDataView
view, EpiNotifyArgs ar)
at Epicor.Mfg.UI.FrameWork.EpiViewNotification.Invoke(EpiDataView
view, EpiNotifyArgs args)
at Epicor.Mfg.UI.FrameWork.EpiDataView.Notify(EpiNotifyArgs args)
at
Epicor.Mfg.UI.FrameWork.JobLib.EpiDataViewFilterManager.EDV_EpiViewNotification(EpiDataView
at
Epicor.Mfg.UI.FrameWork.JobLib.JobTransactionHelper.initializeViews()
at Epicor.Mfg.UI.App.JobEntry.Transaction.initializeViews()
at Epicor.Mfg.UI.App.JobEntry.Transaction.GetByID(String jobNum)
----------END
This is the base module.
After contacting epicor they told me to run conversation # 9527, but I
still get this error message. I am able to delete the job and
recreate, which resolves the error.
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
error message:
Error Detail
Stack Trace
value)
text)
at
at
value)
at
at
at
----------END
