Job Entry: Limiting actions, processes
Thanks for confirming it. I'm in the process of writing a BPM to handle it.
--- In vantage@yahoogroups.com, "pklein256" <pklein@...> wrote:
> We are at V.405A and process security has a bug - so it does not work. If Process security actually worked at this level, that would be your answer. I worked with Tech support on this issue a while back and they claim the process security works at their current level - so their solution was to go up to the latest patch.
> --- In vantage@yahoogroups.com, "mustardbuzzards" <c.edwards@> wrote:
> > Ver: 8.03.405A
> > My goal is to limit the Job Entry screen to maintaining job material. I have customized the screen to disable all tabs/fields except for the material tab. The problem is how to prevent a user from creating or deleting an assembly, operation, etc via the tree contect menu?
> > I've looked at process security, but it does not seem work.
> > Thanks
> > Clinton
Ver: 8.03.405A
Clinton
--- In vantage@yahoogroups.com, "mustardbuzzards" <c.edwards@...> wrote:
> Ver: 8.03.405A
> Thanks
> Clinton
