This afflicts our users that use Vantage on a Terminal Server using RDP.
Rebooting the server cures it for quite some time.
If your users complain of the text moving when they click to select text, I have a customization 'fix' for that (supposed to fixed in 8.03.411)
--- In vantage@yahoogroups.com, "brucewbrannan" <bruce.brannan@...> wrote:
> In case any of you are experiencing similar problems, our Engineers sometimes have problems with selecting text in the comment field in job entry. When they click on a word to insert the cursor, it will highlight several words... they can't insert the cursor. And the problem stays. I found this to be an interface issue, having to do with .NET. I went to add/remove programs, uninstalled all of the .NET versions and then downloaded and installed .NET 3.5 SP1, problem solved.
