Job Entry - to warehouse/bin field
When a job is made to order, why is the to Warehouse/bin a required field when issuing parts. Is there a way to make this not required?
These fields are required because they are part of processing the WIP records.
The fields should be defaulting based on part or resource setup though, is this not the case?
regardless of if the job is make to order or make to stock, the system needs to know where the parts are coming from and going to.
Normally the going to bin, is the In-Bin on the scheduled resource for the Operation
