Job Entry Tree Styling
I have code on the Job Entry screen to loop through each of the child nodes after a node has been expanded. It changes the color of the EpiTreeNode to red if the operation is an added op. Unfortunately, the node only changes color if I set the method tree’s UseAppStyling to false. I would like to keep the current style and simply override the color of that specific node. Does anyone know if this is possible?
Note: I change the color to red using myEpiTreeNode.Override.NodeAppearance.ForeColor = Color.Red;
That has always been an “issue” for Epicor if you select UseAppStyling then it forces you to keep that styling of the theme you selected. I’ve tried hacking around for a while and couldn’t figure it out…
Bummer. Thank you for your quick response!
