Job Management / Gen Ops / Job Closing
After you run the capture cos wip process it checkS for those jobs maRked closed
Sent from my Verizon Wireless BlackBerry
Date: Mon, 10 May 2010 09:05:36
To: <vantage@yahoogroups.com>
Subject: [Vantage] Job Management / Gen Ops / Job Closing
I am having a problem reconciling my wip stock levels.
In the 'Job Completion / Closing Maintenance' screen, under 'Current Job Selection', there is a tick box for 'Wip Cleared'.
Would anybody know what this does?
Martin, Electrix.
Martin, Electrix.
The help screen defines it as :
"WIP Cleared
When selected, this check box indicates that job has been removed from
the work-in-progress (WIP) calculations. You cannot change this check
box.
Jobs are not automatically removed from WIP when they are closed.
Instead, a closed job is relieved from WIP after you run the "Capture
COS and WIP Activity" program. This lets you close jobs as they are
finished, since these closed jobs will still appear on your WIP report
until they have been cleared.
If you reopen a job that has already been relieved from WIP, the WIP
Cleared option will remain selected until you post additional costs to
the job."
Mark L. Knight, CPIM
Master Scheduler
Picometrix, LLC (an API company)
2925 Boardwalk
Ann Arbor, MI 48104
Phone: 734-864-5675
Fax: 734-998-3474
mknight@... <mailto:mknight@...>
This transmission contains information belonging to Picometrix and is
confidential and/or legally privileged under all Non-Disclosure
Agreements in place between Picometrix and the recipient. The
information is intended for the use of the individual or entity named
above. If you are not the intended recipient, you are hereby notified
that disclosing, distributing or copying this information is strictly
prohibited. If you have received this email in error, please contact the
sender named above.
Of electrixchris2008
Sent: Monday, May 10, 2010 5:06 AM
Martin, Electrix.
