Any idea why this happens? I create a new order, we use parts on the fly for partNum that do not exist in our part table, for example ‘SN12345’, on the releases detail the ‘Make Direct’ is checked (Make=true), upon save the job gets created but it does not take the order releases quantity and it remains 0.
Darn it couldn’t have been that simple. That’s all I’ve got. Unless someone else knows what might be amiss, sounds like you may need to get Support involved.
Edit: one additional thought… I assume that if you input a prod quantity on the job, then the outstanding quantity updates on the order? If so, is it possible that either a BPM is setting the prod quantity to 0 and/or that someone manually set it? (we all know that’s probably going to be Support’s first question)
Manually updating the production quantity fixes it.
Job Entry program is restricted and not everyone has access to it.
We do not have a solid scenario as to when exactly this happens. So far it is pretty random but I can say it happens perhaps on 1% of the jobs that are created.
There is a JobHead.ProdQty field that’s a aggregation of demand links, so in theory when the JobProd.ProdQty is changed, then that one would be, too. Could try change log on that JobHead field and see if you’re able to gain any insights that way into what might be happening.
