Hi Andrew,
We're on 8.03.403D and I've had the same problem. Epicor told me the problem was fixed in an update, but he could not tell me which update.
At least now I know it's not 405.a!
I've resorted to re-entering the "pull from stock" sub-assemblies into released jobs as a material and deleting the sub-assembly.
This at least gives material handlers a complete pick list.
Adam
Adam
--- In vantage@yahoogroups.com, "andrew.tapper" <atapper@...> wrote:
> Has anyone else had problems with the Job Pick Lists in Vantage 8.03.405a?
> We have run into a couple jobs where after we enter some pull qtys for some assemblies we either get an error when trying to run the pick list or we get a pick list that shows what appears to be multiple on hand locations for an assembly, which don't really exist.
> In looking further into the problem, I found that the XML file for the report seems to be wrong. The multiple on hand location problem is really that these "pulled" assemblies are being handed as JobMtl with a MtlSeq of 0, so you see the first assembly's part number and then the rest of the "on hand" detail is actually the other pulled assemblies.
> Has anyone else experienced this? Does anyone know what causes it and is there a fix?
> Thanks,
> Andrew
