The critical path is identified on the job scheduling board, is this stored in the data anywhere or calculated each time the job scheduling board is opened?
Hi
The data is held in the ResourceTimeUsed table which holds 2 records for each scheduled operation - whatif = 1/0 depending on the scheduling status - moved but not committed and/or scheduled
In most instances the records are the same, unless someone has moved a job schedule but not committed the changes
