Job Tracker
When I entered the Job number it does not showup any info where i brough the BOO and BOM. When I directly in the job entry screen its gives an error like "Application Error
Exception caught in: mscorlib
Error Detail
Message: Item has already been added. Key in dictionary: ‘PONN’ Key being added: ‘PONN’
Program: CommonLanguageRuntimeLibrary
Method: Insert
Client Stack Trace
at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
at System.Collections.Hashtable.Add(Object key, Object value)
at Ice.Lib.Framework.EpiListPickerPanel.FillHashTable(IList1 code, IList1 desc, Hashtable hash)
at Ice.Lib.Framework.EpiListPickerPanel.oDataView_EpiViewNotificationTCodeOnly(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.OnEpiViewNotification(EpiNotifyArgs e)
at Ice.Lib.Framework.EpiDataView.InnerNotify(EpiNotifyArgs args)
at Erp.UI.FrameWork.JobLib.JobTransactionHelper.notifyViewProcessRowRules(EpiDataView edv, Int32 row)
at Erp.UI.FrameWork.JobLib.JobTransactionHelper.initializeViews()
at Erp.UI.App.JobEntry.Transaction.initializeViews()
at Erp.UI.App.JobEntry.Transaction.GetByID(String jobNum)"
I deleted my user ID personalization as well
Looks like to me you have a job with a space as a job number.
