Test Case has more than one assembly in the job? In that case, sub assembly.
Whenyou say test case, do you mean different types of jobs?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Friday, April 12, 2013 9:30 AM
Subject: RE: [Vantage] Job Traveler Barcode Issues
Is it possible that the field is truncated?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
PonyPower362
Sent: Friday, April 12, 2013 11:12 AM
Subject: [Vantage] Job Traveler Barcode Issues
Hi-
I am adding a barcode field on our job traveler based on the
JobAsmbl.PartNum field. The barcode printed out and scanned perfectly fine
on all but one of my test cases where the barcode did not print at all. I
checked the string length to see if there were any hidden non-printable
characters, and string length matches character output. Converted string to
ASCII to verify characters within string were as represented visually, and
that checked out. The barcode field @PrintAsmBCPartNum that is native to the
report prints fine. Anybody have any other ideas as to what would cause this
issue?
Erin Freese
Suburban Manufacturing
Monticello, MN
PonyPower362
Hi-
issue?
Erin Freese
Monticello, MN
