Thanks for all the responses. I downloaded the Crystal patches and it
worked perfectly.
Thanks again,
Kelly
worked perfectly.
Thanks again,
Kelly
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@d...> wrote:
> Kelly,
> I just made the same jump this past weekend.
> Some of the things I have found that were a pain...
> 1. All custom RB reports need to be looking at the new database (I
copied
> mine to a new location and modified them early)
> 2. There are several new Crystal reports, some work, some don't.
> 3. get to patch 511. It fixes the quote form. (I did not, and now
will
> have to tonight).
> 4. Any custom reports set up in the custom reports screen will need
their
> location updated.
> 5. Patch the 6.0 before you convert your data. Saves a step and has
other
> benefits that can save data that they just discovered they left out
of the
> original release (any custom menu items for instance).
> 6. Our server is the same, and the workstations did not change, but
> performance is very slow. Even adding 512meg ram to the server to
give it a
> gig did not help much. I will be testing further to see what is to
blame
> most. Server is only 800 mhz, and the clients are typically 233mhz
to
> 350mhz with NT or 2000. Can't wait to have a budget again. :)
> 7. If you have ABOM, you will need to set the permissions on the
workbench.
> Good Luck.
> Practice the upgrade plenty,
> Aaron Hoyt
> Design Standards
> -----Original Message-----
> From: Kelly Wendorff [mailto:kelly.wendorff@s...]
> Sent: Monday, August 18, 2003 8:41 AM
> To: 'vantage@yahoogroups.com'
> Subject: [Vantage] Job Traveler in 6.0
> Greetings,
> We are in the process of testing 6.0 (currently running 5.0). We
are
> scheduled to go live one week from today (Aug 25).
> I loaded Crystal 8.5 to run with 6.0. We use a modified version of
the
> Vantage traveler. When I try to run the modified report with the
new
> vantage database - the first several pages work fine but the last
few pages
> have no detail. The header shows, but nothing below it. Any
suggestions on
> where I should start?
> Thanks,
> Kelly Wendorff
> Cost Accounting Manager
> SteelCraft Corp
> 105 SteelCraft Drive
> Hartford, WI 53027
> 262-673-6770 ext 195
> 262-673-4380 Fax
must have
Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo
com/info/terms/
