Thank you Rob! I was trying to make that waaaaaay more complicated than it was. I was just about to investigate doing it with VB code somehow....
-Adam
-Adam
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> Configure the print form the way you want it, go to actions and select
> Save Defaults.
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of adam.whipp
> Sent: Monday, October 12, 2009 11:23 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Job Traveler Print Dialog Customization
> Is there a way to default a check box to "checked" when you bring up the
> print traveler dialog box? For example, we want "Print Bar Codes" to be
> checked by default every time we go to print a traveler. I went in
> through customization and I don't see a property for "checked" on the
> check box control that I can easily change to true or false. Thanks for
> help!
> -Adam
