Job traveler report in 5.1
Vantage has it's own set of .dll's for Crystal in the M:\vantage\dll folder. If an individual workstation has a newer dll (ie. from CR 8.5) when a Vantage Report is run, it seems to grab the workstations .dll first. These dll's need to match.
One way to find out if the .dll's are the problem - run the report on a workstation that does not (and never has had) CR 8.5 on it. If the report works like you see it in CR Designer, then you know the faulty workstation may have a dll problem. If the report looks just as bad on ANY workstation, then... perhaps one of the Vantage .dll's is screwed up???
My experience was (when using CR 8.5). The machine that had 8.5 on it had some trouble running Vantage Crystal reports - even if they looked fine on every other workstation. This only affected two reports in our situation.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, November 30, 2001 5:51 PM
Subject: [Vantage] Re: job traveler report in 5.1
I did that too. Didn't work. How is it possible for the Crystal
program to cause this when the software is installed on a different
pc than the vantage program?
I don't get it.
Rick
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Deleting the whole Seagate directory after uninstalling 8.5 would
be a good start to killing all the old .dll's.
> Troy Funte
> Liberty Electronics
> From: Shirley Graver
> To: vantage@y...
> Sent: Friday, November 30, 2001 2:52 PM
> Subject: RE: [Vantage] Re: job traveler report in 5.1
> Probably, if you have it available, use CLEAN SWEEP to clear out
an unwanted
> install. This relatively inexpensive program will COMPLETELY
clear a
> program. When done, I turn clean sweep on itself to wipe it
clean. Thus
> paying homage to the gods of licensing and clean living.
> Shirley H. Graver
> (End User)
> Systems Administrator
> Rubber Associates Inc.
> -----Original Message-----
> From: Thad Jacobs [mailto:tjacobs@k...]
> Sent: Friday, November 30, 2001 2:43 PM
> To: 'vantage@y...'
> >I uninstalled 8.5 but that didn't help.
> it is my experience that uninstalling crystal doesn't remove all
of the
> dll's, unless you happen to get lucky. When moving from 7 to 8, I
ended up
> giving up and reformatting my hard drive.
> From: cadcam@u...
> [mailto:cadcam@u...]
> Sent: Friday, November 30, 2001 11:37 AM
> To: vantage@y...
> Vantage support also thinks Crystal 8.5 is the cause. So I
uninstalled
> 8.5 but that didn't help. I'm using the updated traveler for 5.1
> Dazed and Confused.
> Rick
> > If this is an untouched Vantage report, then the only thing I
can
> think of is that the Crystal DLL,s are messed up. This is the
type
> of thing that can happen if you are using Crystal 8.5 instead of
> Crystal 8. Isn't there an updated Traveller for 5.1 also?
> > Troy Funte
> > Liberty Electronics
> > From: cadcam@u...
> > To: vantage@y...
> > Sent: Thursday, November 29, 2001 3:22 PM
> > Subject: [Vantage] job traveler report in 5.1
> > I'm having problems with the job traveler report in ver. 5.1
> > Epicor has so far been unable to solve this problem. The
report
> prints
> > but the formating is all wrong. Operation comments are
printing
> in
> > the wrong place, letters are missing in headers, assembly
levels
> are
> > not printing on new pages...( this is epicors report, not a
> custom
> > one.)
> > A little help please.
> > Thanks.
> > Rick
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must have already linked your email address to a yahoo id to
enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services
goto:
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
must have
> already linked your email address to a yahoo id to enable
access. )
Builder and
http://docs.yahoo.com/info/terms/
must have
access. )
Builder and
Service
> <http://docs.yahoo.com/info/terms/> .
> ADVERTISEMENT
must have already linked your email address to a yahoo id to enable
access. )
Service.
ADVERTISEMENT
Epicor has so far been unable to solve this problem. The report prints
but the formating is all wrong. Operation comments are printing in
the wrong place, letters are missing in headers, assembly levels are
not printing on new pages...( this is epicors report, not a custom
one.)
Thanks.
Rick
If this is an untouched Vantage report, then the only thing I can think of is that the Crystal DLL,s are messed up. This is the type of thing that can happen if you are using Crystal 8.5 instead of Crystal 8. Isn't there an updated Traveller for 5.1 also?
Troy Funte
Liberty Electronics
one.)
Thanks.
Rick
ADVERTISEMENT
Rick,
I just had a couple other thoughts...
What printer are you printing to? Does the Print Preview Look OK?
Some DotMatrix printers don't handle crystal Characters very well. Try a different printer and see if it looks different. If so, then the printer driver is the culprit. I have found on our dot matrix printer for Invoices, I have to put the text box in a formula for it to print properly. It is something to do with the way the print driver converts the output to graphics for printing.
Troy Funte
Liberty Electronics
one.)
Thanks.
Rick
ADVERTISEMENT
Hi, We experienced the same problem with Vantage 5.1 in printing
travelers and found there is patch for that problem on the Epicor
website. You can download it. Its called traveler.rpt
Becky Burmeister
MathStar, Inc.
Sent: Thursday, November 29, 2001 7:33 PM
Subject: Re: [Vantage] job traveler report in 5.1
Rick,
Troy Funte
Liberty Electronics
one.)
Thanks.
Rick
ADVERTISEMENT
Vantage support also thinks Crystal 8.5 is the cause. So I uninstalled
Dazed and Confused.
Rick
> Troy Funte
> Liberty Electronics
> From: cadcam@u...
> To: vantage@y...
prints
in
are
custom
> one.)
> Thanks.
> Rick
> ADVERTISEMENT
access. )
Service.
it is my experience that uninstalling crystal doesn't remove all of the
dll's, unless you happen to get lucky. When moving from 7 to 8, I ended up
[mailto:cadcam@...]
Dazed and Confused.
Rick
> Troy Funte
> Liberty Electronics
> From: cadcam@u...
> To: vantage@y...
prints
in
are
custom
> one.)
> Thanks.
> Rick
> ADVERTISEMENT
access. )
Service.
Search back through the post of the past 6-8 months for keyword "Crystal".
There has been a lot of discussion about 8.5 and trying to go back. Some
info about crpe32.dll and various places the uninstall leaves .dll files.
If you haven't received and saved them via regular email you should be able
to search the web-site version (see link at bottom of any message).
-Todd C.
Sent: Friday, November 30, 2001 1:37 PM
Dazed and Confused.
Rick
> Troy Funte
> Liberty Electronics
> From: cadcam@u...
> To: vantage@y...
prints
in
are
custom
> one.)
> Thanks.
> Rick
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.3270152.1261774/D=egroupweb/S=17050071
83:HM/A=879171/R=0/*http://www.fastweb.com/ib/yahoo-57f>
<http://us.adserver.yahoo.com/l?M=178320.1681224.3270152.1261774/D=egroupmai
l/S=1705007183:HM/A=879171/rand=734317659>
Probably, if you have it available, use CLEAN SWEEP to clear out an unwanted
install. This relatively inexpensive program will COMPLETELY clear a
program. When done, I turn clean sweep on itself to wipe it clean. Thus
Shirley H. Graver
(End User)
To: 'vantage@yahoogroups.com'
[mailto:cadcam@...]
Dazed and Confused.
Rick
> Troy Funte
> Liberty Electronics
> From: cadcam@u...
> To: vantage@y...
prints
in
are
custom
> one.)
> Thanks.
> Rick
> ADVERTISEMENT
access. )
Service.
Deleting the whole Seagate directory after uninstalling 8.5 would be a good start to killing all the old .dll's.
Troy Funte
Liberty Electronics
Shirley H. Graver
(End User)
[mailto:cadcam@...]
Dazed and Confused.
Rick
> Troy Funte
> Liberty Electronics
> From: cadcam@u...
> To: vantage@y...
prints
in
are
custom
> one.)
> Thanks.
> Rick
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
I don't get it.
Rick
> Troy Funte
> Liberty Electronics
> To: vantage@y...
an unwanted
clear a
clean. Thus
> Shirley H. Graver
> (End User)
> To: 'vantage@y...'
of the
ended up
> From: cadcam@u...
> To: vantage@y...
uninstalled
> Dazed and Confused.
> Rick
can
type
> > Troy Funte
> > Liberty Electronics
> > From: cadcam@u...
> > To: vantage@y...
report
> prints
printing
> in
levels
> are
> custom
> > one.)
> > Thanks.
> > Rick
> > ADVERTISEMENT
You
enable
> access. )
goto:
> Service.
must have
access. )
Builder and
must have
access. )
Builder and
Service
> ADVERTISEMENT
access. )
Service.
