I see the duplicated resources on that job.That's probably what the problem is. I think it probably happened because I tried to DMT in a related operation. There is a bug in the get details routine where the operations of assemblies that are phantom BOM's end up with the same Operation sequence as the level above.
A little back story if anyone is interested:
We put on a backflush operation on all Phantom BOM's so that we can put a comment on the traveler that says what part number the phantom BOM is in case they need to look up a print.The phantom function pushes the operation up to the next level and it works well. Because of that we usually get about 5-10 backflush operations on the top level and the related assemblies are supposed to be related to the backflush operation that was on it's original BOM in the part master (with a new sequence number). When it works it's really nice because you can flatten the structure but still be able to follow the structure through the prints.
That being said, the operations below these assemblies (like a lasered part that goes into a weldment) assign the same number (for example op 70 is a valid backflush op on the top level) and the operation for an assembly below will be set as 70, which is invalid. It's supposed to be 10 for laser. You can go through the job and fix them manually, but it's a pain so I tried a DMT for this job since there were so many. Obviously it caused a problem.
I have the bug called into Epicor service, but I have yet to have them fix an actual problem with the program. The best that I have gotten for any issue is a work around via an updateable dashboard, and sometimes (If I can explain it well enough) I get an answer on what we are doing wrong in the case of user error.
