We are having issue getting job assemblies to load via dmt what are the columns I need. that make that work.
Going off memory here: I believe it is Job#, Assembly#, Part Number, and probably a parent assy#… (parent for top level is probably 0… top assembly # is always zero). The predecessor is that you need the Job table created first.
We got the columns created and working but we keep getting this error message with an error occurred while expecting the command definition. see the inner exception for details.
