JobHead CheckOff1
I want to make use of the “CheckOff” fields in JobHead - How do I maintain the “Label” for the fields…
Optional Job check off number 1. The label for this field is found in JCSyst. If the label field is blank then field should be invisible.
These “check offs” will be used for selecting jobs. An example would be a “Engineering” or “Purchasing” check off.
Never mind – I found it :slight_smile:
