JobMtl Change Log
Ted, I don't know if you got your answer on this but here is my 2-bits of info.
The ChgLog.TableName is the active table (i.e. your JobMtl) and I think your ChgLog.Idetifier is your Master Table. Regarding Jobs, the Key2 field identifies JobNum~Assmbl~Op.
--- In vantage@yahoogroups.com, "tkoch77" <tkoch77@...> wrote:
> Hi all,
> I am trying to create a BAQ that will have a date range and project ID filter to select change log records. In the ChgLog table the job number is stored in Key1, however, Key2 holds a string like this 000905~1~70, which isn't very useful for anything. Is there anyway to link the chglog table to the jobmtl table, has anyone accomplished this?
> TIA,
> -Ted
Hi all,
TIA,
-Ted
