JobMtl Qty check on POLine or Rel
Does anyone have a simple BPM that throws up a warning message when a buyer enters a JobMtl PO Line for a Qty that exceeds the Required Quantity on the Assembly?
I am stuck on grabbing the ReqQuantity from JobMtl where Job, Asm, and Mtl are matching.
Thanks!
Paul
So far I am running into a wall; I have created a UD on the PODetail table to capture the JobMtlQty. This is what I would like to use in a condition, since the OurQty field from PO Entry is a calculated field.
I am stuck at trying a Method Directive now because I couldn’t get anywhere with the Data Directive. At least Method Directive has the Set by Query widget, that seems to do what I want.
I am thinking this would be a two step process: 1) Pre Process on GetNewPORel and use Fill Table By Query (couldnt get the Set by Query widget to work). Then Step 2) Post Process: Use a condition to compare the newly populated JobMtlQty UD field to the PO Detail Order Qty, and throw a warning if there is a mismatch.
Where am I going wrong?
Thanks!
@psiebers I was able to mock something up that I think would give you the results your looking for.
Here’s the warning I get when the OrderRel Qty is greater than the JobMtl Qty on the PO.
I was able to do this with a Data Directive.
Here’s the condition. “Number of rows in the designed query is more or equal to 1”.
Tables & Relationship
Criteria
Then used Show Message widget.
Let me know if this works for you or if you have any questions.
Fernando,
This is exactly what I needed to drive it home! Thanks!
I made a couple of edits:
I used JobMtl.RequiredQty for my Table Criteria
I am also going to add a condition that exclude Approvers from this rule, as we might have occasions that we want to buy more than the Job specifies.
Paul
Paul, That’s awesome! Glad to hear it worked for you. Yeah that makes sense to exclude the approvers. I had to make another BPM similar to this and I was having issues breaking out of the specified table on the Data Directive but the condition used here is a great way to evaluate other tables conditions (in my use cases).
Cheers,
