Journal Entries for Jobs
The following journal entry was created for a job:
1.) Dr Raw Materials - for the difference between the standard cost of
raw materials consumed and the standard cost of the finished product
2.) Cr WIP - for the standard labor and burden
3.) Cr Finished Goods - for the standard cost of one of the raw
materials consumed
4.) Dr WIP - for the difference between the actual cost to produce the
product less the standard raw material cost of the product
5.) Cr COGS - for the difference between the actual cost to produce the
The only part of this entry I understand is number 2, I do not
understand the rest at all. I am certain the set up is not correct and
causing the majority of this mess, but I cannot find where to fix the
set up. Where do I check to make sure set up is pointing to the right
accounts?
Michelle C. Grman
Assistant Controller
KERUSSO
The Greek word means - To herald divine truth as a public crier; to
preach the gospel.
P.O. Box 32
Berryville, AR 72616
Phone: 870-423-6242 Ext. 267
Fax: 870-423-3568
Web Site: www.kerusso.com
Revolutionize your jewelry sales with the Beacon Accessory Center:
"The Beacon is a SERIOUS MARGIN MAKER! We've sold half of the product in
less than a month!"
-Ron Kuzman, Mgr., Sonrise Christian
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
