Mark,
I set up my kanban on warehouse level and I assign the PO with Lines for that part. When my onhand qty falls below min level, it did not do what I think it should do "create releases on the PO", also for production kanban, I am not sure how the system can create a job to remake the part.
Please kindly explain.
Thank you,
Grace
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wagner
Sent: Monday, October 12, 2009 9:20 AM
Subject: Re: [Vantage] Kan Ban
Have not used the E9 version but in 8.03.xx you define the KanBan type on the Part Plant/Warehouse/KanBan tab (purchase or production). If it is a purchase you have to setup a PO with Lines for that part for a supplier. As the onhand falls below a certain quantity (set up for min/max and safety stock) it creates releases on that PO. There is no automatic e-mailing to a supplier but a BPM could probably work. If it is a production KanBan it will create jobs with a KB prefix and you can issue materials to that job
Â
Thank you,
Grace
Â
