Kanban testing
Instead of using 250% us the dollar equivilant; i.e., $10 x 250% = $ 25.00.
Check flat instead of percentage.
Sent: Thursday, April 14, 2005 1:05 PM
Subject: [Vantage] Re: Kanban testing
The workcenter is set up as a percent -- 250% of labor. If I use the
same workcenter as operation 3 of 4 it calculates correctly. It
doesn't matter which workcenter it is -- just that it is the last
operation.
--- In vantage@yahoogroups.com, "Michelle de la Vega"
<mdelavega@c...> wrote:
> We do the same thing...how is your work center set up? With a flat
burden rate or as a percent?
> If it is a percent what is the number you are using?
> Michelle de la Vega
> Business Applications Manager
> Cold Jet, LLC
> 513-831-3211 ext 400
> 513-831-1209 fax
> www.ColdJet.com
> From: Sandy Morse [mailto:smorse@b...]
> Sent: Thursday, April 14, 2005 11:09 AM
> Subject: [Vantage] Kanban testing
> I am on 6.1 and am trying to test the "Kanban receipts" option on
Job
> Management. Every time I run the option the burden on the last
> operation is way out of whack. I have labor = burden checked and
the
> burden rate is 2.5 times labor. The labor on the last operation is
> 43.93 so the burden should be around 109.83 -- instead it is 904.44.
> All the other operations tie out. I have tried several part numbers
> with the same result. At first I had only three operations -- the
> problem was on the third op. Then I added an operation and the
problem
> moved to the fourth op. The burden doesn't seem to be an
accumulation
> of all the other burdens so I'm not sure what is going on. Anybody
have
> any ideas or have this happen to them?
> Sandy Morse
> BVR Technologies Company
> 815-874-2471 x112
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
I am on 6.1 and am trying to test the "Kanban receipts" option on Job
operation is way out of whack. I have labor = burden checked and the
problem was on the third op. Then I added an operation and the problem
moved to the fourth op. The burden doesn't seem to be an accumulation
of all the other burdens so I'm not sure what is going on. Anybody have
Sandy Morse
815-874-2471 x112
We do the same thing...how is your work center set up? With a flat burden rate or as a percent?
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Sandy Morse
815-874-2471 x112
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
operation.
> Michelle de la Vega
> Cold Jet, LLC
> 513-831-1209 fax
> www.ColdJet.com
Job
the
problem
accumulation
have
> Sandy Morse
> 815-874-2471 x112
access. )
> _____
> Yahoo! Groups Links
