Keeping the Epicor logo on
"We considered going with the time-out approach, but certain users need
Vantage most of the day, and wouldnt be very happy being kicked out of
vantage after doing something else for a certain amount of time."
We use Mike Podlin's Time-out utility, which can be 'turned off' for certain
workstations. I have it set to shut vantage down after 15 minutes idle on
most PC's. However, I have it off completely on the three manager's PC's
so that no matter how long they have vantage open it will not close. On
others, I have the time set to a half hour. Also, with this utility, if you
have one session of vantage open or starting, and you double-click the icon
again, you get a message that you already have a session open and it will
not let you start another session on that PC. This utility has been great
in saving us from having to buy more licenses and go around to manually kick
people off who are not using it.
Anyone have any ideas on how to write an expression that will find
and list the earliest Labor entry date (LaborDtl.Clockindate)
between 3 different manufacturing operations (OpMaster.OpCode).
The manufacturing process could begin on one of three different
OpCodes. I need to track the date manufacturing begins. Using
earliest Labor entry won't work because we log time on design
first. I need to list the three OpCodes and be able to list the
operation and the start date of the manufacturing process. Or
should I set up a user/memo field that can be used to manually enter
the date manufacturing begins? That would be easier but means another
entry someone had to make. Thanks -Kevon
Off the top of my head...
Create a calculated date field with something like:
IIF(OpCode = 'op1' or OpCode = 'op2' or OpCode =
'op3',Clockindate,12/31/2025)
--fill in you target op codes for op1,op2,op3
--12/31/2025 or any sufficiently far away date.
Then sort ascending on this date field. Any non-relevant op codes will sort
at end.
You could also supress printing band lines with 12/31/2025 date or set a
count and suppress all but the first date seen.
Todd C.
Harvey Vogel Mfg. Co.
Sent: Monday, April 30, 2001 1:23 PM
Subject: [Vantage] Help with RB expression
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=190481.1393724.2979175.2/D=egroupmail/S=1700007183:N/
A=613930/?http://www.newaydirect.com> www.newaydirect.com
<http://us.adserver.yahoo.com/l?M=190481.1393724.2979175.2/D=egroupmail/S=17
00007183:N/A=613930/rand=809087394>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Maybe this ...
You could use earliest labor entry where LaborDtl.OpCode <> '???'
OR
You could use earliest labor entry where LaborDtl.OpCode = '???'
Jonathan Tompkins
> From: khuntley@... [SMTP:khuntley@...]
> http://groups.yahoo.com/group/vantage/files/. Note: You must have
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Try this, create a Calculated filled IIF(OpCode = Code1 or OpCode = Code2 or
OpCode = Code3, OpCode, ""). Then run a filter on the report Where OpCode =
Calculated Field.
Ed Giallombardo
Major Industries, Inc.
7120 Stewart Ave
Wausau, WI 54403
(715 ) 842-4616
<http://docs.yahoo.com/info/terms/> Terms of Service.
Anyone have any ideas about keeping the startup Epicor logo on till the
login screen appears. I have very impatient users, they will click on the
icon 4 or 5 times then not clear the "extra" login occurances they've
started. I thought I'd try and keep the startup logo on for a while longer
to slow down their itchy fingers.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
I do not think you can change the time that the startup screen appears. One
of the functions of the Vantage mainmenu.w is to close the startup window,
check database versions and then startup the logon window. Depending on
network traffic, there can sometimes be a delay in the time it takes to
close the splash screen and bring up the logon window. You can try using an
application/program that limits Vantage to running only one copy at a time
on the pc.
I've had this problem before mostly with the slower shop pcs (one case, I
had one pc running 27 copies of Vantage at once).
Michael Podlin
Sent: Tuesday, May 01, 2001 8:20 AM
Subject: [Vantage] Keeping the Epicor logo on.
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Besides telling users to be patient, I've noticed using a black and white splash speeds things up a tiny bit. You could customize it to say "PLEASE WAIT FOR THE LOGIN...This can take 20 seconds..." or something like that.
Also, have you tried running the System Management/Utilities/Cache Schema Changes? It shortens a 20 second login by about 3 to 4 seconds.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, May 01, 2001 9:20 AM
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Really?! I tried it (Vantage 3) and it actually took *longer* to start
up! We see about 4 - 5 seconds start up on windows 9x on 100Mb network,
and even quicker (2 - 3 sec) on NT clients, with times being about equal
between Vantage 3 and 4. 10Mb slows to about 15 seconds; but with the
cache thing, all of those were about 20% slower?!
-Wayne Cox
PS... just me, or is yahoo massively delayed (hours?) in reflecting things
today?
Using my very unofficial watch, on V. 5 on a Win95 (winsock 2), it gave me a couple seconds. As you mentioned, NT is considerably faster than Win95.
Troy
Sent: Tuesday, May 01, 2001 11:42 PM
Subject: [Vantage] Schema cache
-Wayne Cox
today?
I use a VB Script file to prevent multiple launches of Vantage. I uploaded the file to the yahoogroups files section. This script uses WMI (Windows Management Instrumentation) to see if the "prowin32.exe" process is running, if it is, it tells the user and exits, if it's not it launches Vantage. WMI is standard on Win2k and WinME (it also installs with SMS clients), you have to download it and install it for NT4 and 95/98. The download is at: http://msdn.microsoft.com/downloads/default.asp?URL=/code/sample.asp?url=/msdn-files/027/001/576/msdncompositedoc.xml%ef%bf%bd. Open the file in notepad and�set the 2 variables in the script that�customize to your environment...
strCompName = should be set to Your company name.
strVantageLaunch = should be set to the same string that your Vantage shortcut uses to launch vantage (you will probably only need to check the drive letter
Replace your current Vantage shortcuts with this script file and change the Icon to the Vantage icon.
Matt
Sent: Tuesday, May 01, 2001 1:24 PM
Subject: RE: [Vantage] Keeping the Epicor logo on.
I do not think you can change the time that the startup screen appears.� One
check database versions and then startup the logon window.� Depending on
close the splash screen and bring up the logon window.� You can try using an
on the pc.�
Michael Podlin
login screen appears.� I have very impatient users, they will click on the
started.� I thought I'd try and keep the startup logo on for a while longer
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
E*TRADE. It's your money.
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/.%ef%bf%bd Note:� You must have already linked your email address to a yahoo id to enable access.�
Pretty nifty, Matt.
I wonder if there is anything that can be done on the Progress side? I am
still manually going in and killing users with multiple logins...
Paul
Sent: Thursday, May 03, 2001 11:16 AM
dn-files/027/001/576/msdncompositedoc.xml . Open the file in notepad and set
the 2 variables in the script that customize to your environment...
Â
Â
drive letter
Â
Â
Matt
on the pc.Â
Michael Podlin
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
http://groups.yahoo.com/group/vantage/files/.%c2%a0 Note:Â You must have already
linked your email address to a yahoo id to enable access.Â
You shouldn't�get multiple logins if you use this script. I don't know enough about progress to go messing around with killing users! (What an interesting job we have...)
Sent: Thursday, May 03, 2001 10:42 AM
Pretty nifty, Matt.
I wonder if there is anything that can be done on the Progress side?� I am
Paul
dn-files/027/001/576/msdncompositedoc.xml�. Open the file in notepad and�set
drive letter
Matt
on the pc.�
Michael Podlin
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Yahoo! Groups Sponsor�����
E*TRADE. It's your money.�����
linked your email address to a yahoo id to enable access.��
Click Here!
You can use a TimeOut parameter/application to close the idle multiple
logins.
To: 'vantage@yahoogroups.com'
Pretty nifty, Matt.
Paul
Â
Â
drive letter
Â
Â
Matt
on the pc.Â
Michael Podlin
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Yeah, I've been tempted to kill a few users for some of their antics, but
the law tends to frown on that practice (not to mention HR)!
Steve Sanders
Delta Centrifugal Corp.
Pretty nifty, Matt.
Paul
running,
WMI
have
set
drive letter
the
Matt
One
an
on the pc.
Michael Podlin
longer
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
already
already
However, that approach could singnificantly reduce the demand for licenses,
and possibly eliminate the need for the "Could anyone not using Vantage
please log out" intercom page so frequently heard throughout the week in our
firm.
Sent: Thursday, May 03, 2001 10:58 AM
logins.
Pretty nifty, Matt.
Paul
Â
Â
drive letter
Â
Â
Matt
on the pc.Â
Michael Podlin
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
