Kinetic 2024.2 Error having both call context field and field query in Email/message widgets
Hello,
Running into an interesting issue where having a combination of CallContextData.character01 and a field query in an email or message widget is giving me the compilation error:
I’ve verified that I can have the email/message send as long as it is one or the other, just not both.
This is only an issue in the Kinetic version, am still able to do this in the classic screen. Has anyone run into this issue or found a way to fix? (On-prem 2024.2.10)
Report it as a bug with steps - what service you use, how does query look like, etc
Will do, was just curious if anyone had found a fix at this point. Checked patch documentation and didn’t see anything that related to it.
well, this is the first time I hear about this issue and you don’t provide information about what error it is, what exactly you are doing :woman_shrugging:
Ah, sorry about that. Forgot to fix the screenshot I posted earlier of the error.
Well, went to recreate as I did 5 times this morning and it did not pop up, so guess I missed something on the debugging side.
