We are getting this message “Entity DmsStorageType with specified keys is not found” as part of a large stack message… any stabs at what might be the issue?
We use attachment links for the attachments in our environment and get this whenever we try to download or view them. Tried searching high and low for anyone with same issue.
I think it’s because our document type is blank on every XFileRef record and I think with the newer versions it’s required whereas in the older one’s when these attachment links were created, it wasn’t… waiting on support to confirm…
2025.2 in Gov Cloud. Not the same message but all our local attachments now say “Error received from Edge Agent Unable to validate call”. They were working before the update and other Edge Agent functions are working (printing, classic screens).
Okay thank you Olga as always. What do we do then? I found that if I make a Document Type called “Default” and link it to that attachment type you pictured above and then DMT that onto all of my xfileref records, the edge agent works…
What do we do, use the workaround or wait for edge agent?
I don’t know what waiting means because our users need to be able to view these attachments as part of the ISO process in manufacturing. I may just have to act. I was just trying to get a sense of timing.
Are you going to relay this to support on our case, or? Is there any way you can relay the supporting tests you did so I can relay it to them and get a PRB started?
Well it will take time to fix and test in any case.
If you cannot wait, then you have to switch.
Also if people only view them and not add new, then maybe adding fake file attachment as default will help…
When you say that, did you create a document type called “Default” or did you just DMT the word “Default” in the DocTypeID column without creating the document type?
