Kinetic Event Trigger on Multiple Columns
What format do the names of the Columns need to be to use multiple columns for a single event trigger? I have tried commas, semicolons, and spaces between the names. Is this even possible to use multiple columns or does a separate event need to be created for each column?
I don’t believe that’s possible. If I were you, I would put all of the common widgets in a separate event and then create multiple triggers for each column that calls the event-next widget and point it to your common widget event.
Thanks, Hannah. Followed your advice and working as expected.
