Wanted to thank all who responded to my Labeling questions!
FYI, I ended up giving up on the label programs since I discovered I
could create a Crystal "Label" report that would satisify my needs.
Writing a report to print on a Zebra printer (sideways) isn't the
easiest thing to do but it can be done. The main 'report' label is
basically a holder for multiple subreports in different sections. I
then created suppression logic into the sections so that only the
appropriate customers label would print.
The benefit of this method was that it allowed the users to use the
standard Label print function from Customer Shipment Entry.
Thanks again everyone!
Mike
Of Brian Stenglein
Sent: Wednesday, August 02, 2006 6:32 AM
Subject: [Vantage] Re: Label programs and Vantage via ODBC
I've also created a couple of different label apps in Access. They
allow the data to be extracted from Vantage and gives the user an
opportunity to fill in some extra fields before printing in an easy
to use interface. Some are simple apps that print out on avery
labels on regular laser printers.
The one that we print out the majority of our shipping labels from is
very complex. When the shipping clerk has all the data ready the
Access app exports a flat file with all of the info to a program
called Jet Form Central that sends the label to be printed on our
Zebra Printers. Virtually every big customer of ours has their own
barcode specifications, so have several dozen specific layouts to
manage. This process was somewhat difficult to get set up, but it
offers far more flexibility than anything we could do with just
Vantage and Crystal alone.
Brian Stenglein
Clow Stamping Co.
"Butch Menge" <bmenge@...> wrote:
Behalf
Mike
Of Brian Stenglein
Brian Stenglein
Clow Stamping Co.
>ODBC.
> I use Microsoft Access to do my labels and it works great with the
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Butch
Behalf
> Of Mike LoweBarTender
> Sent: Friday, July 28, 2006 1:10 PM
> Subject: [Vantage] Label programs and Vantage via ODBC
> Greetings All and Happy Friday!
> I'm wondering if anyone out there is using either LabelView or
> to access Vantage (6.1, 9.1D) data via ODBC?against
> For whatever reason, I can't seem to make these programs work
> the Progress DB using ODBC. Crystal works fine, just not these label[Non-text portions of this message have been removed]
> programs.
> As a side note, are there any other programs being used to generate
> labels that connect directly to the Vantage db?
> Thanks in advance,
> Mike Lowe
> Connor Manufacturing Services
