Hi All,
I am working on labor costing and am running into an issue with how labor burden is being calculated. We are working with resources that are representative of crews, therefore we are adjusting our labor rate and burden rate to reflect the number of people represented in that crew. i.e. Crew of 2 = $15/person x 2 = Labor Rate , same logic applies to burden. We do our best to estimate the resource as close as possible to the actual reporting that will occur out on the shop floor. For example if we are most efficient using that crew of two that is what we use to estimate on our methods.
As you know the actual labor rate is determined based on the employee labor rate. No issues there since the actual employee is set up the same way our resources are, therefore our cost is still calculated accurately regardless of if there is a change between the estimated crew and actual crew.
I am finding however that the actual burden rate is still driven by the burden rate on the resource. This is causing us to over calculate the burden rate when the actual employee crew reporting to a job differs from the estimate. For example, we estimated the job to be completed using a crew size of 2 and the burden rate is based on two people doing the work. If we are logging the actual hours using a crew of 4 because we need to complete something sooner, the burden rate is still reflecting only two people.
Estimate = Crew of 2 @ 1 hour. Burden Rate of 30 (2 people x 15 per person) = total burden of 30
Current Actual = Crew of 4 @ 1 hour. Burden rate of 30 (2 people x 1 hour x 15 per person) = total burden of 30
True Actual = Crew of 4 @ 1 hour. Burden Rate of 60 (4 people x 1 hour x 15 per person) = total burden of 60
Does anyone know of a way to control the actual burden rate at the employee level rather than being dependent on the resource?
