True - but that won't 'fix' any received inventory value. Also not sure if that would fix COGs for make direct jobs/sales lines.
Rob
Rob
--- On Mon, 4/27/09, saab_barracuda <chris.clunn@...> wrote:
Subject: [Vantage] Re: Labor Edit after Capture and Post V6 versus V8
Date: Monday, April 27, 2009, 9:47 AM
In V8, you can still fix the labor costs on the job if you reopen and use Job Adjustment. It would be a separate entry though and wouldn't change the original labor entry. The effects on payroll would vary depending the specific error, how you do the adjustment, and your payroll process.
Chris
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...> wrote:
> True on v8
> Rob
> --- On Fri, 4/24/09, Randy <rweber@...> wrote:
> From: Randy <rweber@...>
> Subject: [Vantage] Labor Edit after Capture and Post V6 versus V8
> To: vantage@yahoogroups .com
> Date: Friday, April 24, 2009, 4:44 PM
> I am told by my accounting person that in V6, we were able to use Labor Edit on a job that had been closed even after a capture and post. Now in V8, we cannot do this as it says the labor has been posted.
> Can anybody confirm this is true - that something has changed from V6 to V8?
> Thanks in advance,
> Randy Weber
