Labor Edit Report Indirect Comments
I'm not sure which version you are on but if it's the text based Progress report, you are out of luck. Those can't be changed. You'll need to do a custom report if you want to change anything.
Personally, I think the Labor Edit Report just about useless since it's based on clock-in date instead of payroll date. So if you're going to do a custom report for this, you might consider switching it to payroll date.
--- In vantage@yahoogroups.com, "wl_bl" <wl_bl@...> wrote:
> Does anyone know if there is a way to print the Labor Notes for Indirect activities on the Epicor supplied Labor Edit Report?
> Thanks,
> Wendy Hodgson
Wendy Hodgson
I should add that in most cases weve built our own versions of those
types of reports in crystal (i.e. BAQ crystal report).
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of wl_bl
Sent: Friday, May 29, 2009 11:20 AM
Subject: [Vantage] Labor Edit Report Indirect Comments
Wendy Hodgson
I noticed that it's a progress report...good luck with that.
Rob Bucek
FAX: 715-284-4084
Of wl_bl
Wendy Hodgson
Unless you know progress programming, no you cannot edit this report...
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of wl_bl
Wendy Hodgson
