Are you attempting this with a client side customization or are you using a BPM as a method to direct the value?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jeff_o_h
Sent: Monday, October 24, 2011 5:17 PM
Subject: [Vantage] Labor Entry Default Value for Indirect Code
In Labor Entry on the Labor Tab I would like to default the Indirect Code to a value, "Paid Time Off", if the Labor Type is "Indirect". I have been able to capture when the Indirect code is selected but have not figured out how to set the default value of the Indirect Code. I have not found any examples in the messages here or in Epicweb. Has anyone been able to do this with the Indirect combo box or something similar?
Jeff Hanka
senior application developer
TECT Corporation
19420 84th Ave South, Kent, WA 98032
www.TECTcorp.com
jhanka@...<mailto:jhanka%40tectcorp.com>
Rob Bucek
FAX: (715)284-4084
Jeff Hanka
TECT Corporation
www.TECTcorp.com
