Labor Rate Posted to Jobs
PDR should match to labordtl.laborrate * labordtl.laborhrs. Ensure the following with notes in parentheses.
labordtl.company eq "your-company"
labordtl.activetrans eq no (skip active transactions)
labordtl.payrolldate ge date-1 and labordtl.payrolldate le date-2
labordtl.hedseq ne 0 (skip adjustments)
You also may need to: round(labordtl.laborrate * labordtl.laborhrs,2)
----- Original Message -----
Sent: Tuesday, September 19, 2006 3:17 PM
Subject: RE: [Vantage] Labor Rate Posted to Jobs
PDR may be using the costing labor rates setup by operation
(OpMaster.ProdLRate). You can adjust your operation standards in the
Operation Master Maintenance. The Labor Detail table shows the
employee's "Labor Rate" (EmpBasic.LaborRate) which is setup in the
Employee maintenance (under Finance --> Payroll), which is also not
necessarily the same as their "Pay Rate" (that's another field in the
payroll table).
No matter which rate is used, it shouldn't come out that far off.
Of brucewbrannan
Sent: Tuesday, September 19, 2006 4:19 PM
Subject: [Vantage] Labor Rate Posted to Jobs
Vantage 6.1:
We are trying to write a report to examine labor details. When we
print a production detail report and compare to our new report. We
are multiplying the LaborDtl.LaborHrs * LaborDtl.LaborRate per line
and then summing all the lines. Our report's numbers are 6-7 times
higher than the production detail report. Obviously, our rate is
incorrect, but where can we find the rate that the production detail
report is using?
Any help is greatly appreciated!
Bruce Brannan
Engineered Products Dept.
Vantage 6.1:
report is using?
Bruce Brannan
Using RB? Or even if not what are the sort and group levels? This sounds suspiciously like a multiple assembly levels issue where the totals get multiplied by the number of levels. In which case only accumulate at Assembly level 0 (zero) the top level.
Or...Linking operations on a job to the laborDtl records could be resulting in multiple instances in which case force the link toselect only level zero.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of brucewbrannan
Sent: Tuesday, September 19, 2006 3:19 PM
Vantage 6.1:
report is using?
Bruce Brannan
payroll table).
Of brucewbrannan
Vantage 6.1:
report is using?
Bruce Brannan
