LaborDtlSeq Blank Title 128457
#ygrps-yiv-1273269980 P.ygrps-yiv-1273269980c366dae8-2371-40b4-9e76-fe7790caf4bc { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1273269980 LI.ygrps-yiv-1273269980c366dae8-2371-40b4-9e76-fe7790caf4bc { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1273269980 DIV.ygrps-yiv-1273269980c366dae8-2371-40b4-9e76-fe7790caf4bc { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1273269980 TABLE.ygrps-yiv-1273269980c366dae8-2371-40b4-9e76-fe7790caf4bcTable { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1273269980 DIV.ygrps-yiv-1273269980Section1 { }
This is implemented as a Sequence.
In a progress database sequences are first class citizens one can read the value, set and increment the value they are not a table.
In a SQL database sequences are normally handled in another way, but to keep consistency with how progress works it is implemented as Calvin mentioned in the _SEQT tables.
This is not something you should be manipulating.
If you do have an issue with sequences i.e. you cannot create a record because the sequence is out of sync with the data say after a dump and load, you run the conversion to reset sequences which can be run at any point in time (but outside of business hours really).
Regards,
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mvissuet@...
Sent: 19 February 2014 00:47
Subject: [Vantage] LaborDtlSeq
In what data table is the LaborDtlSeq kept?
Or how does Epicor know which one to use next?
Epicor 9.05.606
Progress
Stephen Edginton (Beng) | Technical Director
Mobile:  +44 7734 858415
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
Epicor 9.05.606
Progress
The LaborDtl table has a field LaborDtlSeq. In my 905 db it is the 4th column in the table. I believe it is maintained by a sequence table: SEQT_LaborDtlSeq
HTH,
Calvin Dekker
[cid:image001.jpg@01CF2CE0.61C48800]<http://www.codabears.com/>
630-672-7688 x1484
[cid:image002.png@01CF2CE0.61C48800] <https://www.facebook.com/CodaBearsInc> [cid:image003.png@01CF2CE0.61C48800] <http://www.linkedin.com/company/codabears-inc> [cid:image004.png@01CF2CE0.61C48800] <https://twitter.com/CodaBearsInc>
Sent: Tuesday, February 18, 2014 6:47 PM
Epicor 9.05.606
Progress
LaborDtl table. I believe this field is auto incremented by 1 each time a new LaborDtl record is created.
Sent: Tuesday, February 18, 2014 7:46 PM
Epicor 9.05.606
Progress
How does Epicor know what number to use next?
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Cell (619)507-2311
Anaheim Office (714) 693-1260
San Diego Office (619)670-3900
Fax (714) 693-1252
mvissuet@...
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties.  Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Wednesday, February 19, 2014 7:29 AM
Subject: Re: [Vantage] LaborDtlSeq
Epicor 9.05.606
Progress
__________ Information from ESET NOD32 Antivirus, version of virus signature database 9443 (20140219) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
I don’t think there is a way to set it manually. It is autogenerated and it is more like a record number.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Marco Vissuet
Sent: Wednesday, February 19, 2014 8:52 AM
Subject: RE: [Vantage] LaborDtlSeq
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...
Epicor 9.05.606
Progress
http://www.eset.com
