LaborHed Clock In date
The ClockInDate and ClockInTime are also adjusted based on the Grace
Periods defined in the Company Config. So you might give employees a
+/- five minute grace period, and MES will adjust based on your config,
but also record the actual values separately for audit purposes.
-bws
Of Jose Gomez
Sent: Thursday, March 24, 2011 8:21 AM
Subject: Re: [Vantage] LaborHed Clock In date
ClickInDate
The clock in date of the clock in time field. It is created using the
ActualDate and may be rolled forward/backward if the clock in time is
adjusted across midnight. For example, when an employee clocks in prior
to
midnight, but shift starts at midnight or later, this situation causes
the
default to be ActualDateIn + 1.
ActualClockInDate
The actual date at the time of clockin. Labor Collection uses the system
date to create this field. Labor entry allows entry of this field and
then
uses it to generate the default for the adjusted "ClockInDate". This
field
is provided mainly for audit purposes.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Thu, Mar 24, 2011 at 7:38 AM, Chris Thompson
<chriselectrix@...>wrote:
> Hi All
> What is the difference between LaborHed.ClockInDate and
> LaborHead.ActualClockInDate?
> Thanks.
Hi All
Thanks.
ClickInDate
adjusted across midnight. For example, when an employee clocks in prior to
midnight, but shift starts at midnight or later, this situation causes the
ActualClockInDate
date to create this field. Labor entry allows entry of this field and then
uses it to generate the default for the adjusted "ClockInDate". This field
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Mar 24, 2011 at 7:38 AM, Chris Thompson <chriselectrix@...>wrote:
> Hi All
> Thanks.
