Hi all,
I was wondering if anyone out there has input a date into a LaborHed UD field using a BPM when an employee clocks out? If so, how did you do it?
I created a Pre-Processing BPM on EmpBasic.ClockOut to set Date01 on the current active LaborHed record for the employee that is clocking out. I've found that when they clock out of MES and then try to clock back in, it acts like that LaborHed record is still the active one and doesnt ask them to select a shift, but if they clock out and in again it works normally and asks for a shift.
-Ted
-Ted
