Laser Signing Payroll Checks
At 11:31 AM 8/12/2004, you wrote:
> > Is anyone laser printing the signature onto their payroll checks? Can
> > this be done in the same pass through the printer when you print the
As the others pointed out, it's not a Crystal form that you can modify.
But as an easy work around, you could try this utility:
www.fineprint.com It's share-ware for about $45 per copy. It lets you use
save any print job, and use it as an overlay for other print jobs.
So you could scan the signature, put it into a word doc to control size and
position, then superimpose it on all the checks.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
actual check? If so, where is the file containing the format for the
payroll check that I would insert a signature image into?
Thanks in advance,
Jeff Milbrath
Controller
Hartford Finishing, Inc.
If its AP Checks then you can do that in \"VantageDirectory"\userform\chkprint.rpt
You will need Crystal Reports
Hope that helps,
Jeremy
Sent: Thursday, August 12, 2004 10:24 AM
Subject: [Vantage] Laser Signing Payroll Checks
Thanks in advance,
Jeff Milbrath
Controller
Yahoo! Groups Links
Thanks, but I am already aware of where the AP check form is, I just
can't seem to find the PR check format file.
Jeff
--- In vantage@yahoogroups.com, "Jeremy Leonard" <jeremy.leonard@f...>
> Hope that helps,
> Jeremy
> From: j_milbrath [mailto:jeffrey.milbrath@h...]
> Thanks in advance,
> Jeff Milbrath
> Controller
access. )
> Yahoo! Groups Links
Jeff,
I could be wrong but I do not believe the payroll checks can be modified.
I'm on 5.2 and this is the case.
Have a Nice Day,
Dina Hieber
Vamco International, Inc.
Phone (412) 963-7100
Fax; (412) 963-7160
www.vamcointernational.com
_____
Sent: Thursday, August 12, 2004 10:31 AM
Subject: [Vantage] Re: Laser Signing Payroll Checks
Jeff
> Hope that helps,
> Jeremy
> Thanks in advance,
> Jeff Milbrath
> Controller
access. )
> Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129unck9r/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705007183:HM/EXP=1092411151/A=2164331/R=0/SIG=11eaelai9/*http:/www.n
etflix.com/Default?mqso=60183351> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
:HM/A=2164331/rand=395862539>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Up through 6.1 you are right Dina.
Unfortunately, the only modification you can make to the PR check form
is to change the fonts a bit. That is part of the INI file, but I have
not dealt with this in a couple of years, so I can't say just where.
It is not a Crystal form, and Epicor has not made it one through 6.1
even with a ton of begging. Please do call support and add your name to
the list of companies that need to modify that form. There is power in
numbers, but this seems to require nothing short of a demonstration
outside Epicor HQ.
Please add yourself to the list with support.
Aaron Hoyt
Hittite Microwave
Sent: Thursday, August 12, 2004 11:38 AM
Subject: RE: [Vantage] Re: Laser Signing Payroll Checks
Jeff,
modified.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
_____
just
Jeff
> Hope that helps,
> Jeremy
checks? Can
print the
for the
> Thanks in advance,
> Jeff Milbrath
> Controller
You
enable
access. )
goto:
> Yahoo! Groups Links
You must have
access. )
Builder and
ADVERTISEMENT
D=gr
ww.n
s/S=
_____
Yahoo! Groups Links
access. )
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129og2u2o/M=298184.5285298.6392945.3001176/
D=groups/S=1705007183:HM/EXP=1092411539/A=2164330/R=0/SIG=11eamf8g4/*htt
p://www.netflix.com/Default?mqso=60183350>
s/S=:HM/A=2164330/rand=386931004>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
They can't be modified on 6.1 yet either.....
Julie
Mercury Minnesota Inc.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, August 12, 2004 10:38 AM
> Jeff,
> Have a Nice Day,
> Dina Hieber
> Fax; (412) 963-7160
> _____
> From: j_milbrath [mailto:jeffrey.milbrath@...]
> Jeff
> > Hope that helps,
> > Jeremy
> > Thanks in advance,
> > Jeff Milbrath
> > Controller
> access. )
> > Yahoo! Groups Links
have
> ADVERTISEMENT
> _____
> Yahoo! Groups Links
> Yahoo! Groups Links
