Last Saved By Blank Title 107860
You are right Mark, I was just picking the first one that came to mind
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Feb 23, 2012 at 1:48 PM, Mark <mark_wonsil@...> wrote:
> Jose,
> --- In vantage@yahoogroups.com, "Anon" <jgiese@...> wrote:
> > I don't know much of anything about BPMs either :S.
> > I need it to trigger anytime a transaction is performed so I don't know
> that there would be any conditions, and I need to set ShortChar04 = UserID.
> Why In-Transaction vs. Standard? My understanding (which could be wrong)
> is that In-Transaction does one update at a time in case there's a
> dependency where Standard does all at once which is why it's "faster".
> Thanks!!!
> Mark W.
Trying to add a custom last saved by feature to a screen. How can I go about setting ShortChar04 = userID beforeAdapterMethod, update.
I would like to do it in the screen customization I have started. Is beforeAdapterMethod the best event to use for this type of thing?
The best thing to do is use a BPM it will be the only thing that wil ALWAYS
fire. Is there a reason why you want to do it as a customization and not a
BPM?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> BPM?
And if you're on version 9, the best-er thing is a BPM Data Directive instead of a Method Directive. This will catch all updates regardless of the business object used.
Mark W.
I don't know anything about data directives. Sounds like the better way to do it. Do you have any general direction on this?
> > BPM?
> Mark W.
Data directives work almost exactly like BPM's except at a lower level, if
you can do a BPM you can do a Data Directive, simply do an
In Transaction Directive for the Table you want to store the info. Works
just like a BPM you have your COnditions and your Actions, one of which is
Set Field to X
Let me know if you need more details.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> ALWAYS
> not a
> > > BPM?
> > Mark W.
I need it to trigger anytime a transaction is performed so I don't know that there would be any conditions, and I need to set ShortChar04 = UserID.
> Set Field to X
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > --- In vantage@yahoogroups.com, "Mark" <mark_wonsil@> wrote:
> > ALWAYS
> > not a
> > > > BPM?
> > > Mark W.
Never mind I figured it out
ttclient.curruid
> > Set Field to X
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > ALWAYS
> > > not a
> > > > > BPM?
> > > > Mark W.
System Management | Business Process Management | Setup
Data Directive
Pick a table. In your case, a Standard directive will suffice. Enter conditions, actions and then Enable. Fairly straight forward.
Mark W.
> > > BPM?
> > Mark W.
Jose,
Why In-Transaction vs. Standard? My understanding (which could be wrong) is that In-Transaction does one update at a time in case there's a dependency where Standard does all at once which is why it's "faster".
Thanks!!!
Mark W.
I did this with a pre-processing BPM on the UD01.Update method, I assume
it would work with the Update method for other objects.
Conditions: none
Actions: set the UD01.ShortChar03 field of the changed row to the
DCD-USERID expression
and set the UD01.Date03 field of the changed row to the TODAY expression
That records the *last* change person & date, overwriting it *each* time
the record is saved. If you want to record the original creator only,
do a post-processing BPM on UD01.GetaNewUD01 instead.
Brian.
Of Anon
Sent: Thursday, February 23, 2012 1:43 PM
Subject: [Vantage] Re: Last Saved By
UserID.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
level, if
Works
which is
> Set Field to X
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
way to
wil
> > ALWAYS
and
> > not a
> > > > BPM?
Directive
regardless of
> > > Mark W.
