Dim str As <a rel=“nofollow” title="System.StringCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:2.0.0.0:b77a5c561934e089/System.String”>String
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Property Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.DMRNum As Integer
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:DMRNum:Int32”>DMRNum = 0
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Property Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.RMANonConfNum As Integer
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:RMANonConfNum:Int32”>RMANonConfNum = 0
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Property Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.RestrictToNonConf As Boolean
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:RestrictToNonConf:Boolean”>RestrictToNonConf = False
If ((Not Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgsCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/caArgs:Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs”>caArgs Is Nothing) AndAlso (Not str = Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgs
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/caArgs:Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs”>caArgs.<a rel=“nofollow” title="Mode As String
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.AD.CorrectiveAction:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs/Mode:String”>Mode Is Nothing)) Then
If Not (str = “InspProc”) Then
If (str = “DMR”) Then
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:DMRNum:Int32”>DMRNum = Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgs
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/caArgs:Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs”>caArgs.<a rel=“nofollow” title="dmrNum As Integer
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.AD.CorrectiveAction:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs/dmrNum:Int32”>dmrNum
<a rel=“nofollow” title="System.StringCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:2.0.0.0:b77a5c561934e089/System.String”>String.<a rel=“nofollow” title="System.String.Format(ByVal String, ByVal Object)
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:2.0.0.0:b77a5c561934e089/System.String/Format(String,Object):String”>Format(“DMRNum = {0}”, Me.<a rel=“nofollow” title="trans As Transaction
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:DMRNum:Int32”>DMRNum)
If (Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgsCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/caArgs:Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs”>caArgs.<a rel=“nofollow” title="nonConfNum As Integer
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.AD.CorrectiveAction:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs/nonConfNum:Int32”>nonConfNum <> 0) Then
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:RMANonConfNum:Int32”>RMANonConfNum = Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgs
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:RestrictToNonConf:Boolean”>RestrictToNonConf = True
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.DisableNonConfNum()
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/DisableNonConfNum()”>DisableNonConfNum
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://mscorlib:2.0.0.0:b77a5c561934e089/System.String/Format(String,Object):String”>Format(“NonConfNum = {0}”, Me.<a rel=“nofollow” title="trans As Transaction
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:RMANonConfNum:Int32”>RMANonConfNum)
End If
ElseIf (str = “RMA”) Then
Me.<a rel=“nofollow” title="baseToolbarsManager As UltraToolbarsManagerCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/baseToolbarsManager:Infragistics.Win.UltraWinToolbars.UltraToolbarsManager”>baseToolbarsManager.<a rel=“nofollow” title="Property Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.Tools As RootToolsCollection
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Infragistics2.Win.UltraWinToolbars.v10.3:10.3.20103.2015:7dd5c3163f2cd0cb/Infragistics.Win.UltraWinToolbars.UltraToolbarsManager/property:Tools:Infragistics.Win.UltraWinToolbars.RootToolsCollection”>Tools.<a rel=“nofollow” title="Property Infragistics.Win.UltraWinToolbars.ToolsCollectionBase.Item(ByVal key As String) As ToolBase
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Infragistics2.Win.UltraWinToolbars.v10.3:10.3.20103.2015:7dd5c3163f2cd0cb/Infragistics.Win.UltraWinToolbars.ToolsCollectionBase/property:Item(String):Infragistics.Win.UltraWinToolbars.ToolBase”>Item(“NonConfTool”).<a rel=“nofollow” title="Property Infragistics.Win.UltraWinToolbars.ToolBase.SharedProps As SharedProps
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Infragistics2.Win.UltraWinToolbars.v10.3:10.3.20103.2015:7dd5c3163f2cd0cb/Infragistics.Win.UltraWinToolbars.ToolBase/property:SharedProps:Infragistics.Win.UltraWinToolbars.SharedProps”>SharedProps.<a rel=“nofollow” title="Property Infragistics.Win.UltraWinToolbars.SharedProps.Enabled As Boolean
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Infragistics2.Win.UltraWinToolbars.v10.3:10.3.20103.2015:7dd5c3163f2cd0cb/Infragistics.Win.UltraWinToolbars.SharedProps/property:Enabled:Boolean”>Enabled = False
End If
Else
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Property Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.TranType As String
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/property:TranType:String”>TranType = “InspProc”
End If
End If
If Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.ReopenDenied()
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/ReopenDenied():Boolean”>ReopenDenied Then
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Infragistics2.Win.UltraWinToolbars.v10.3:10.3.20103.2015:7dd5c3163f2cd0cb/Infragistics.Win.UltraWinToolbars.ToolsCollectionBase/property:Item(String):Infragistics.Win.UltraWinToolbars.ToolBase”>Item(“ReopenTool”).<a rel=“nofollow” title="Property Infragistics.Win.UltraWinToolbars.ToolBase.SharedProps As SharedProps
End If
MyBase.<a rel=“nofollow” title="Epicor.Mfg.UI.FrameWork.EpiBaseForm.OnFormLoaded()CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.EpiClientLib:2.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.FrameWork.EpiBaseForm/OnFormLoaded()”>OnFormLoaded
If (Not Me.<a rel=“nofollow” title="caArgs As CorrectiveActionArgsCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/caArgs:Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionArgs”>caArgs Is Nothing) Then
Me.<a rel=“nofollow” title="trans As TransactionCTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.CorrectiveActionForm/trans:Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction”>trans.<a rel=“nofollow” title="Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction.setCorrectiveActions()
CTRL+Click to open in new tab." target="_blank" href=“http://127.0.0.1/roeder/dotnet/Default.aspx?Target=code://Epicor.Mfg.UI.CorrectiveActionEntry:9.5.606.0:5d3fa3c7105d7992/Epicor.Mfg.UI.App.CorrectiveActionEntry.Transaction/setCorrectiveActions()”>setCorrectiveActions
End If
Jose C Gomez
T: 904.469.1524 mobile
On Tue, Sep 17, 2013 at 4:23 PM, Jose Gomez <jose@...> wrote:This form uses a CorrectiveActionArgs which is an extension of LFO you need to import the caArgs from the AD.CorrectiveAction.dll then fill it out and sent it in as the LFo
On Tue, Sep 17, 2013 at 10:57 AM, Karen Schoenung <kschoenung@...> wrote:Â<div> <p></p><div><p class="ygrps-yiv-773577935MsoNormal"><span style="font-size:11.0pt;color:#1f497d;">Dim lfo as LaunchFormOptions = new LaunchFormOptions()<u></u><u></u></span></p><p class="ygrps-yiv-773577935MsoNormal"><span style="font-size:11.0pt;color:#1f497d;">Â Â Â lfo.ValueIn = "Epicor.Mfg.UI.CorrectiveActionEntry"<u></u><u></u></span></p>
   Dim CorrectiveActionEntryForm As UIReflector = ProcessCaller.LaunchCallbackForm(otrans, "Epicor.Mfg.UI.CorrectiveActionEntry", lfo)
Â
This will launch the form (version 8.03.409c)…You will still need to work on passing the arguments.
Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of smyers@...
Sent: Monday, September 16, 2013 5:17 PM
Subject: [Vantage] launch form args for DMR processingÂ
Â
Hello,
I have previously opened forms with pre-populated launch form information in code, for example:
Â
Serial Number Assignment:
Dim SNlfo As New Epicor.Mfg.UI.App.SerialNumberAssignmentEntry.SNAssignmentArgs(JobNo, 0, "", 0, True)
Â
Order Job Wizard:
Dim lfo As New Epicor.Mfg.UI.App.OrderJobWizEntry.OrderJobWizArgs(Order, 0, 0, true)
Â
Can anyone tell me the statement to use when launching corrective actions from DMR processing please?
Â
For example:
Â
Dim lfo As New Epicor.Mfg.UI.App.CorrectiveActionEntry.??????args(0,true,"")
Â
Steve
</div> <div style="color:#fff;min-height:0;"></div>
