I’m familiar with using process.caller to call BAQ reports using the menu ID and passing parameters in there. And I’ve opened Bartender labels and passed parameters using their engine with a string. But What I need to do is open a ODBC Crystal report form the MES menu and pass some parameters to that and I don’t think I’ve seen any information on that. I’ve searched around and haven’t found anything specific to this. Could someone help me out, what is the syntax I need to to use to launch an ODBC crystal report and pass it some parameters? I’m doing this in a button click and I’m passing it some info i should be able to get from the screen, employee number and today’s date. Any help is appreciated!
I had a similar problem (passing parameters to an ODBC based CR report), and was told that the CR Runtime in Vantage won’t pass parameters. You need a third party CR viewer, but then launching that from Vantage might be just as hard.
Here’s a thought on kind of a hack. It requires an existing report that: a) can be launched from MES, and b) has the data your ODBC report would use as parameters.
Make a new style for the report launched from MES.
In CR designer, hollow out the report (obviously a copy of the report).
Insert your ODBC CR report as a sub-report.
Link the fields from the original report’s RDD, to the parameters of the CR report.
You might need to make a modified RDD (report data definition) to best match your parameters.
Thanks for the response. I was afraid of this and have looked around and I think I found a report I could use to hollow out. I am able to pass parameters to the RDD report I’m hollowing out using process.caller though correct (not sure with Vantage)? I think I can use Employee Badge, which is accessible from the Menu.
