My bad. The solution is correct. Thanks again Bernie!
--- In vantage@yahoogroups.com, "bjcracosta" <racosta@...> wrote:
> It seems my elation was premature. :(
> The solution looked correct. But now the following error is thrown:
> Error Detail
> Specified cast is not valid.
> Stack Trace
> at Epicor.Mfg.UI.Rpt.PackingSlipPrint.PackingSlipPrintForm.OnFormLoaded()
> at Epicor.Mfg.UI.FrameWork.EpiBaseForm.formLoaded()
> It's quite frustrating!
> --- In vantage@yahoogroups.com, "bjcracosta" <racosta@> wrote:
> > Excellent! Thank you! This is one for the archives!
> > --- In vantage@yahoogroups.com, Bernie Walker <bwalker@> wrote:
> > > Here is what happens in dll file:
> > > Dim list As New ArrayList
> > > list.Add(edvPackoutView.dataView.Item(0).Item("PackNum").ToString) list.Add(Convert.ToBoolean(edvPackoutView.dataView.Item(0).Item("IsInvoiced").ToString))
> > > Dim launchObject As New LaunchFormOptions
> > > launchObject.ValueIn = list
> > > launchObject.IsModal = True
> > > ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UIRpt.PackingSlipPrint", launchObject, True)
> > > You will have to substitute the appropriate EpiDataView name from your customization for edvPackoutView
> > > -----Original Message-----
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Reggie Acosta - El Monte
> > > Sent: Tuesday, August 25, 2009 7:44 PM
> > > To: vantage@yahoogroups.com
> > > Subject: RE: [Vantage] LaunchFormOptions for Epicor.Mfg.UIRpt.PackingSlipPrint
> > > The vantage program is Customer Shipment Entry, Epicor.Mfg.UI.CustShipEntry.dll. It's launched by the "Print" entry under "Actions".
> > > Thanks,
> > > Reggie Acosta
> > > > From: Bernie Walker [mailto:bwalker@]
> > > > Sent: Tuesday, August 25, 2009 4:34 PM
> > > > To: Reggie Acosta - El Monte
> > > > What vantage program do you launch the pack slip report from?
> > > > I will look in the dll file and see what I can find
