Lead time on manufactured parts
It does not have any direct impact. Fab part LT's change constantly with your load as even unfirmed MRP jobs are scheduled (and likely have unique LT's depending upon competing load - particularly in a finite environment).
It is for reference only unless your are doing dual internal/external (supplier) sourcing. Typically you would have more control over your own internal processes than a remote supplier - so you might initially have the part set to Purchased, generate a PO to cover 50-80% of the predicted requirements over time (if the part is commonly used) and then flip the part back to Fab so MRP generates unfirmed Jobs to fill in the peaks and valleys of your requirement needs over time.
Rob
Sent: Monday, May 18, 2009 11:23:07 AM
Subject: [Vantage] lead time on manufactured parts
i do not believe that lead time entered in the part plant record has any effect on manufactured items, but this is being questioned by my co-workers and i can not find definative documentation to prove this one way or another. if anyone knows the answer please chime in.
thanks for your time,
bill king
bill king
