Lead Time on PO Deatil
>> how the Lead Time field is calculated or populated on the PO Detail
From the E9 Help for LeadTime on the PO Lines
calcLeadTime - display only calendar days (7 days/week)
- Data source hierarchy
-- First, use supplier price list lead time if exists
--- Next, use the Part master, plant lead time if exists
Can anyone explain to me how the Lead Time field is calculated or populated on the PO Detail?  I thought I could be adjusted on the PO but it stays grayed out.  Doe is just pull from either the Supplier Part List or Part Plant....depending what is populated?
Struggling with lead time....
thanks Kim
Did you try adjusting it on the release instead of the detail line?  If it is greyed out it may be that you have multiple release against the line itself.
M. Manasa Reddy
IT Manager
PH: 240-268-0400  x1208
Email: manasa.reddy@...
Sent: Monday, November 23, 2015 8:25 AM
To: yahoogroups <vantage@yahoogroups.com>
Subject: [Vantage] Lead Time on PO Deatil
thanks Kim
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
I actually  created a new line....on an existing PO and then tired creating a new PO....maybe I messed up my steps...
On Monday, November 23, 2015 9:10 AM, "Manasa Reddy manasa.reddy@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-36310059yiv5117580315ygrp-text">
  <div>
M. Manasa Reddy
IT Manager
thanks Kim
</div>
<div class="ygrps-yiv-36310059yiv5117580315yqt3610095473" id="ygrps-yiv-36310059yiv5117580315yqt99937"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315 -- #ygrps-yiv-36310059yiv5117580315ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp #ygrps-yiv-36310059yiv5117580315hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp #ygrps-yiv-36310059yiv5117580315ads {
margin-bottom:10px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp .ygrps-yiv-36310059yiv5117580315ad {
padding:0 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp .ygrps-yiv-36310059yiv5117580315ad p {
margin:0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mkp .ygrps-yiv-36310059yiv5117580315ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ygrp-lc {
font-family:Arial;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ygrp-lc #ygrps-yiv-36310059yiv5117580315hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ygrp-lc .ygrps-yiv-36310059yiv5117580315ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity span {
font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity span span {
color:#ff7900;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315activity span .ygrps-yiv-36310059yiv5117580315underline {
text-decoration:underline;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315attach div a {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315attach img {
border:none;padding-right:5px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315attach label a {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315bold a {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 dd.ygrps-yiv-36310059yiv5117580315last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 dd.ygrps-yiv-36310059yiv5117580315last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 dd.ygrps-yiv-36310059yiv5117580315last p span.ygrps-yiv-36310059yiv5117580315yshortcuts {
margin-right:0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315attach-table div div a {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315attach-table {
width:400px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315file-title a, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315file-title a:active, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315file-title a:hover, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315file-title a:visited {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315photo-title a, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315photo-title a:active, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315photo-title a:hover, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div.ygrps-yiv-36310059yiv5117580315photo-title a:visited {
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 div#ygrps-yiv-36310059yiv5117580315ygrp-mlmsg #ygrps-yiv-36310059yiv5117580315ygrp-msg p a span.ygrps-yiv-36310059yiv5117580315yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315green {
color:#628c2a;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 o {
font-size:0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315photos div {
float:left;width:72px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315reco-category {
font-size:77%;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315reco-desc {
font-size:77%;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 .ygrps-yiv-36310059yiv5117580315replbq {
margin:4px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg select, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 input, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg pre, #ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 code {
font:115% monospace;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-mlmsg #ygrps-yiv-36310059yiv5117580315logo {
padding-bottom:10px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-msg p#ygrps-yiv-36310059yiv5117580315attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-reco #ygrps-yiv-36310059yiv5117580315reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-sponsor #ygrps-yiv-36310059yiv5117580315ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-text {
font-family:Georgia;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-text tt {
font-size:120%;}
#ygrps-yiv-36310059 #ygrps-yiv-36310059yiv5117580315 #ygrps-yiv-36310059yiv5117580315ygrp-vital ul li:last-child {
border-right:none !important;}
#ygrps-yiv-36310059
