Lead Time (PartPlant.LeadTime)
Super Dumb Question
Does the “PartPlant.LeadTime” field only apply to PURCHASED parts?
I’m pretty sure it is just for purchased parts.
The field help does not explicitly say this.
I’m noticing some dirty data in my system with M and K parts having values in the “PartPlant.LeadTime” field.
This field is also used in the Min Max Safety Mass Update calculations, manufactured parts included.
Depending on your version, yes, it is only for Purchased parts, but regardless of the part type you can set the value.
There is a separate Mfg Lead Time that can be set via a process that calculates it or it can be manually set.
Time Phase and other programs now (2023.1+?) automatically reference the appropriate lead time field. However, initially I did notice that Safety, Min, Max Update did not reference the Mfg Lead Times, but at least by 2025.1, it did.
So there are different types of lead times for difference types of sourcing.
