Leaving a UD field "editable"
Hi All,
I added a custom field to the Customer Shipment Entry form, and I want to leave it editable after checking the “Shipped” box (like the Tracking Number field behaves). How do I do that?
TIA.
Is this Kinetic UI or WinForm? If it is a WinForm, you can likely use ExtendedProperties to make the ReadOnly false. Otherwise a RowRule may help too.
Hi Jason, thanks for the response!
It is indeed a WinForm on the latest SaaS version.
In the Customization tools Dialog properties the DataReadOnly box is grayed out…I have this field mapped to ShipHead.ShortChar01, is there some other properties tab I’m missing?
Use the wizard to add the required code. The Property can’t be changed.
